General
General
Members Chat Area! AVEVA Wiki
  • Replies 28 replies
  • Subscribers 2 subscribers
  • Views 12 views
AVEVA Wiki
Cody Austin
Cody Austin over 14 years ago
  • Cody Austin
    Good work!! How did you do the screen capture?
    I did the screen capture with a web-application called Screenr.  It's free and you can sign-in with your Google or Twitter account.   [url=http://www.screenr.com]Screenr | Instant screencasts: Just click record[/url]
    Please sign up on the Wiki and add content!
  • karthik
    karthik over 14 years ago
    hi codooaustin
              what is mean by STYPE EQ 'GATE', then how to write in RULE EXPRESSION. if like to change rule to nozz or so and so how can i use this?
  • Cody Austin
    STYPE is just an ATTRIBUTE of they type VALV.  You can replace STYPE with any attribute that belongs to the type NOZZ.  For example:
    If you want to color all NOZZ that have a PURP set to MANWAY, the rule would be,
    PURP EQ 'MANWAY'
  • surya
    surya over 14 years ago
    its very nice idea,please place here pml basics also
  • karthik
    PURP EQ 'MANWAY'
    I tried this same but not change colour. why did you give MANWAY instead of NOZZ. is PURP used for change colour?
  • Cody Austin
    MANWAY and the PURPOSE attribute was an example.  You can use any attribute you like or you don't have to use any attributes at all.  You can just use NOZZ instead of VALV.
    What are you trying to do?
  • Cody Austin
    There are some PML guides on this forum already.  I want to stick with the basic stuff first since it will appeal to more users, then work with the more advanced stuff.
  • karthik
    hi codooaustin,
                      i tried for pipe and branch it's work better, at the same time EQUI, NOZZ, SUBE, rule set is failed to me, i can't change this cases. how can i do this?
  • karthik
    now EQUI,SUBE are working but i can't change NOZZ only, i have one more doubt, in Rule expression column i typed something[ TYPE EQ '.......'], but i selected another case in Gtype column like EQUI or SUBE, BUT result was given to what i selected in Gtype column, not considered Rule expression column. i can't find this.how it is possible?
  • karthik
    [QUOTE=codooaustin;51416]MANWAY and the PURPOSE attribute was an example. You can use any attribute you like or you don't have to use any attributes at all. You can just use NOZZ instead of VALV.
    what is the main purpose of Rule expression.
