INCH DIA. MACRO(NUMBER OFF TACK WELD x SIZE)
    https://aveva.dev-verintcommunity.com/cfs-file/__key/communityserver-discussions-components-files/1598/199412diainchclassify.pmlfnc
  • Dear Sennirajesh,
    with many thanks for your macro,
    i would like get (inch dia.) report from world(all of the site) but your macro we should be in zone level and it is very hard to achieved my target .do you have any recommendation.
    warm regards,
    B.L
  • HI B.L,
    u may run the macro in world level, but the problem here is hierarchy to run the report allowed is CE, so u can run from /*. Here report will be generated for pipe from first piping db in current mdb. If you want to run the report for all project pipes you need to create all the pipes in same db immaterial of sites and zones.
    this may hepl u bit
    thanks
    senni
  • Dear senni,
    thanks for your kind response,
    but you mean that in admin modual i have to creat mdb which is included all design db in current project.how i can creat all pipes in same db when it is not in same db.if it is no trouble for you please more explain or shown sample for me.
    best regards,
    b.l
  • Dear sennirajesh,
    it is kindly appreciated for sharing that pmlfunction.
    good luck.
  • Dear senni,
    I am faced to another error as following:
    (2,441)   CALCULATOR ERROR: Unable to convert string '10in' to a number
    In line 48 of PML function diainchclassify
        !INDICES[$!Y] = !SWSIZE[$!Y].BEFORE( 'mm' ).REAL()
    Called from line 556 of Macro C:\AVEVA\Pdms11.5\DIAINCH\Diainch.exe
       !!diainchclassify( !TOTSWLIST,'LLIST' )
    Could you please help me to fix this error?
    thank you in advance.
  • [QUOTE=HENDIBAHRAM;56623]Dear senni,
    best regards,
    b.l
    hi bl,
    not exactly, again it is a database management concept.
    If you create db's according to discipline in admin module like piping, mechanical, civil, structural and electrical etc., it will leads to minimum db's in project. In admin module while creating db itself u can create default sit for design module and in design module you can create different sites and zones in same piping db according to areas required and u can run the report at /* level to get entire pipes in project. it is one time report generation.
    if you created different db's instead of creating sites and zones for different area in project. it leads to more db's for design, draft, isodraft, cata, prop, etc. here once u run a report from world level in design module it will select first piping db in current mdb created in admin module. it will skip remaining piping db's in the mdb, its a reporting nature. in this case you need to run report individual piping db's. no other way for this pml
    if any pdms guru's will improve this macro for reporting different db's at time will improve productivity of macro
    thanks
    senni
  • Dear senni,
    thanks in advance
    i would like more famolliar with you.please send me your email
  • [QUOTE=sshman;56647]Dear senni,
    hi sshman,
    I think ur using inch system in ur project. am i right?
    If it so please edit diainch.exe file compatible to ur requirement as below.
    open text file and goto line no 48 change  the line from
    to
         !INDICES[$!Y] = !SWSIZE[$!Y].BEFORE( 'in' ).REAL()
    save the file and in design. make pml rehash all in command line and do the reamining as insisted in manual for reporting
    thanks
    senni
