PDMS Guides PARAGON Tutorial - create a valve
  • Replies 50 replies
  • Views 62 views
Juan Manuel Gutierrez Valderrama
Juan Manuel Gutierrez Valderrama over 15 years ago
  • Aleksandr
    Aleksandr over 14 years ago
    for add some valve you mast use next spec text in specon:
    SPECIFICATION /NAME of sample spec
    HEADING
    TYPE            NAME            PBOR0           SHOP            STYP                 CATREF          DETAIL          MATXT           CMPREF       BLTREF
    DEFAULTS
    VALVE    */RNP0WKDD:15           15              TRUE           TEXT 'RNP0WKDD'       /RNP0WKDD       /RNP0WK-D       /RNP0WK-M       /RNP0WKDD-WT        =0
    VALVE    */RNP0WKEE:25           25              TRUE           TEXT 'RNP0WKEE'       /RNP0WKEE       /RNP0WK-D       /RNP0WK-M       /RNP0WKEE-WT        =0
    run it like *.mac file in specon
  • Juan Manuel Gutierrez Valderrama
    Juan Manuel Gutierrez Valderrama over 14 years ago
    [QUOTE=Cheeseman;44278]for add some valve you mast use next spec text in specon:
    HEADING
    DEFAULTS
    Good explanation Cheeseman, thanks.
    cary_kriston, you can add a component also with CATVIEW, but if you like it read the CATVIEW manual for how to see the componets with CATVIEW, it's easy.
    It's better to use SPECON, so do a search in the forum and you can find a lot of good threads about it.
    regards
  • avwf_zplau
    avwf_zplau over 14 years ago
    @ jmgvalderrama,
    Thanks for the good guide.
    On the first page, the pressure rating indicated is 300# and confirmed by the flange diameter (dimension B).
    But the connection of FBB is for 150#. FBD would be more appropriate.
    Something to keep in mind if you intend to update it.
    Thanks.
    When I made the guide I haven't verify the codes because AVEVA teachers write this code.
    By the other hand the guide is only a guideline for modelling components.
    Regards
  • avwf_zplau
    It may have been intentional!
    Nothing like chasing an error message to reinforce the point of having everything spot on.
    [QUOTE=zplau;44335]It may have been intentional!
    OK, next time I'll check better for mistakes.
    Regards
  • Rufus Babatunde Lot
    Rufus Babatunde Lot over 14 years ago
    Hi jmgvaldeerrama,
    Thank you! Thank you for this great work.
    Please keep on the good work.
    Regards,
    Rufus.
  • xgong
    xgong over 14 years ago
    very useful.
  • xgong
    thank you very much.
  • zam
    zam over 14 years ago
    Thanks for share jmgvalderrama..
