PML and PML2 Notepad++ PML Plugin
  • Replies 48 replies
  • Subscribers 18 subscribers
  • Views 274 views
Marjon G. Milloria
Marjon G. Milloria over 14 years ago
Top Replies
  • Mohammad Refaie
    Mohammad Refaie over 14 years ago +1
    I've a comment: According to Software Customisation Reference Manual page 2-148, the substring method takes a parameter ( Substring(REALindex) ). So you need to add the following line after line number…
  • JongSuk Lee
    JongSuk Lee over 11 years ago
    Hi Malonie,
    I have downloaded your xml plugin for Notepad++ however, it's not working with my one (NotePad++ v6.5). It it working only limited version?
    Thank you,
    J.
  • JongSuk Lee
    Malonie,
    I am using Notepad++ 6.5 and your xml doesn't work for me...
    Do you have any idea on this... I followed your instruction though...
  • Ahmed
    Ahmed over 11 years ago
    i now it's an old post but, it gives me the error "failed to load"!!! any recommendations.
  • Admin
    Admin over 11 years ago
    Test this for Notepad++. Place into %APPDATA%\Notepad++
  • Dan Knope
    Dan Knope over 11 years ago
    189173pml.zip
  • Celso Rangel Jr.
    Celso Rangel Jr. over 11 years ago
    Didn't work for me, RUAV, but thanks for trying.
    The rest of you: downgrade to 6.4.5 and it works. Best we can do until someone cleverer than us comes up with the solution :).
  • JongSuk Lee
    It's not perfect though, it's working for me... and I am able to change some settings myself...
    Thank you RUAV
  • Ahmed
    for notepad++ plugin solved the error [COLOR=#333333]"failed to load" [/COLOR],just load the language xml file through language>define your language>import> and it will be loaded at the bottom of the languages menu.
  • jin zhang
    jin zhang over 11 years ago
    thanks for your sharing very much.
  • Kunal C. Jadhav
    Kunal C. Jadhav over 11 years ago
    Hi RUAV, Thanks a lot for sharing this, it is helping me a lot.
    I have one more query, like in other softwares for coding like MS visual studio(MS VS), you get all the variables you defined in the code previously is there any option or any software which can help PML code users in same way it will be great or may be if we can customise MS VS for PML.
