Bolting BOLT LENGTH in OLD METHOD
  • Replies 18 replies
  • Subscribers 2 subscribers
  • Views 46 views
avwf_notiadra29262289
avwf_notiadra29262289 over 15 years ago
  • avwf_notiadra29262289
    P.Basker, hi
    thanks for your expanation.
    But isn't the old method works by taking 1/2 length of flange1 boltref + 1/2 length of flange2 boltref + wafer + extra gasket. If that's true, so the bolt length should be dependent from flange thickness + wafer and gasket.
  • Ganesh Ramakrishnan
    Ganesh Ramakrishnan over 15 years ago
    Yeap !!!! .. But only thing is that the Final lengths shall rounded off which was pre-defined in BLENGTH attribute.
  • Russen Harold Cordovan
    Russen Harold Cordovan over 15 years ago
    Old method works by taking 1/2 length of flange1 boltref + 1/2 length of flange2 boltref + wafer + extra gasket.
    hello pitch.. i just wanna ask about old bolting method.. what's the purpose of setting the bltref of bolt spco and flange spco? Which one is really used? I don't know how isodraft will select the right bolt spec for old bolting method..
    Tanx...
    alinofeire
  • john pitchers
    john pitchers over 15 years ago
    Old and new methods use both.
    Bltref for flange may not be the same as Bltref for the valve.
    You sometimes find that flange thickness for a valve is less than that for a flange.
    [QUOTE=pitch;37263]Old and new methods use both.
    But in new bolting method,setting the bltref for the piping component is not anymore used right? It only used the bltref of the bolt spco selected. Flange thickness will not be based on bltref but on blrfs right? I'm just confuse because since i started using the new bolting method..i never care about blrf setting in piping component spco.. i just set it in blrf of bolt spco...
    Tanx for your response pitch
    [QUOTE=alinofeire;37266]But in new bolting method,setting the bltref for the piping component is not anymore used right? It only used the bltref of the bolt spco selected. Flange thickness will not be based on bltref but on blrfs right? I'm just confuse because since i started using the new bolting method..i never care about blrf [/COLOR][/SIZE]setting in piping component spco.. i just set it in [SIZE=4][COLOR=Red]blrf of bolt spco...
    sorry i had typos ... it's BLTRF not BLRF...
  • john pitchers
    As far as I know nothing has changed.
    BLRF and BLTRF are the same thing. Isodraft uses the BLRF of the component.
    It works out  which bolt speco it needs from the component BLRFs.
    blrfa is for scom and bltrf is for spco.. and in old method blrfa(where the answers are stored in selecting bolt spco) is not used.. how pdms get the answers for the selection of bolt spco.. can you give me little idea about this pitch.. please...
    tanx in advance
