I don't know what is your problem yet.
But in any case it is always recommended to maintain PDMS installation up to date.
You can type Q BANN on the command line to check your fix.
Last one is number 28
Regarding your problem, it would be helpful if you could post other info.
For example tha drawing area of your isometric...
Are you sure the bolt spec in the Paragon picture is the same as the one used/referenced by your piping spec?
