Hi! need to change the bolt length for new bolting method. flange thickness, bore, bolt dia, specifications are same for both the valve and connecting flange.
please suggest the possible solution
thanks
thanks
If you tried to change the flange thickness and nothing happend, you should check the BTSE/BLTP of the BLRFARRAY from the SCOM and see how the Bthkness value is calculated.
Yes...you're right. 95 is not available in length table. 110 is the starting length. I'm sorry and thankyou for your help
Yeah okay. thankyou
I am glad to hear that it went well.
Thank you Emmanuel Desiderio
