Hello,
I am trying to hide pipe specs in design by unsetting the stext of text element pipe specs and also deleting the text element. But it always appears in edsign module and is fully usable.
How can i get around this problem?
Thanks in advance
Hello,
Thanks in advance
ah i see.. i saw that attribute.
thanks for your help and suggestion.
Hello,
Was just about to open another discussion when I saw this trail which seems to relate to an issue we are facing.
We just changed the Pipe spec of a PIPE. After that we can no longer see the PIPE's previous spec in the spec list. In PARAGON the SPEC is not restricted.
Any suggestions?
Thanks for your TIME!
Hello, try to check if the Purpose attribute of the SPEC that is not appearing and compare it to the ones that showing.
You can read here:
https://docs.aveva.com/bundle/e3d-design-cloud/page/913328.html
You have a new way to hide specifications
