[QUOTE=Ranjeet.dhumal;85425]Thanks, I have run this macro, some portion of backing sheet appeared in title block, but rest is not showing, it gives massage in command line,
following are the some lines,
Warning at TEXTPRIMITIVE 23 of NOTE 22 of BACKINGSHEET /PRISM6: specified font not properly defined
Warning at TEXTPRIMITIVE 24 of NOTE 22 of BACKINGSHEET /PRISM6: specified font not properly defined
Warning at TEXTPRIMITIVE 25 of NOTE 22 of BACKINGSHEET /PRISM6: specified font not properly defined
Try with different font for that note..also check color of the texp....query the attributes and set the color....
Thanks Santosh, I have changed colour white in AutoCAD, earlier it was black, now I could able to see all the attributes in Backing sheet in draft module, but if make it plt file & then put in und folder, & extract the iso, then backing sheet text attributes are not showing.
after that I have tried by setting grey colour, but then also all text are not showing plt file & isometrics.
In regular practice of PDMS, which colour has to set.
Kindly advise.
[QUOTE=Ranjeet.dhumal;85441]Thanks Santosh, I have changed colour white in AutoCAD, earlier it was black, now I could able to see all the attributes in Backing sheet in draft module, but if make it plt file & then put in und folder, & extract the iso, then backing sheet text attributes are not showing.
Kindly advise.
