Urgent!! Draw Fatal Error: Foreign PDMS PADD database
  • Hi All,
    Please help!!!!!!!!!!!!!!!!!!!!!!!!!!
    I am getting a fatal error message when entering Draw.
    I have narrowed it down to 2 foreign PADD databases I received from the client. They are PDMS Draft databases.
    There isn't any problem entering Draw without these databases and I have tried using PDMS 12.1 Draft which works.
    Can you not enter into draw with a PDMS PADD database? or is there something else going on?
    This is what appears in the support file
    Draw
    Unhandled Exception:
    System.NullReferenceException: Object reference not set to an instance of an object.
      at Aveva.Pdms.SDInterface.Representation.Cache.RepresentationCache.CacheUserDefinedTypes()
      at Aveva.Pdms.SDInterface.Representation.Cache.RepresentationCache.CacheTypes()
      at Aveva.Pdms.SDInterface.Representation.PdmsRepresentationManager.RegenerateCaches()
      at Aveva.Pdms.SDInterface.PaddAdapter.MdbOpenedEventHandler()
      at Aveva.Pdms.Database.Implementation.DbEventsImpl.postOpenMdb()
      at Aveva.Pdms.Database.Implementation.DbEventsInternal.postOpenMDB(DbEventsInternal* )
      at DLL_Init.OpenProject()
      at Aveva.Pdms.Implementation.PdmsApplicationImpl.internalOpenProjectAfterModuleSwitch()
      at Aveva.PDMS.Shared.StartUp.StartUpCore.OpenProject(CoreOptions opt)
      at Aveva.Pdms.Draw.Draw.Main(String[] Args)
    C:\Program Files (x86)\AVEVA\Plant\E3D1.1.0\draw.exe : A fatal error has been detected.
  • E3D works with PDMS 12.1.SP4 Dabacon Databases
    You should check with your client which PDMS version those databases are coming from...
  • Hi Corrado,
    They are PDMS 12.1.SP3 databases. Is it alright if they are only used for reference/readonly purposes?
