• I can't get it to use the zone names as layers.  I set LayerZone to on and the model entities still come in on layer 0.  Any ideas?
  • Hi All,
    With Plot standard, example (standing on shee level):
    PLOT SHEE DXF /c:\temp\test.dxf CUTMARKS OFF OVER
    This gives a dxf with one layer for each color i Draft (Layer GT_1, GT_2, etc in AutoCad)
    But all element will get a global weight of 0.2500.
    Do anyone have a solution for this?
    It takes a lot of time for a pml function to go thorw the dxf and change from 0.2500 to 0.
    Using configurable plot, full_dxf or graphics_dxf, gives all elements with 0 weight but each site, zone etc will get a Layer in AutoCad, with full_dxf, or all elements in Layer 0 in Autocad with graphics_dxf.
  • [QUOTE=johanlang;99677]Hi All,
    It doesn´t give me any layer, just layer 0 is created. Any suggestion?
  • Are there a similar command than:
         PLOT /drwg1/S1 DXF /%PDMSUSER%\Test.dxf
         PLOT /drwg1/S1 PDF /%PDMSUSER%\Test.pdf
    for export in dwg rather than .dxf or .pdf?
    I tried (but it doesn't work):
         PLOT /drwg1/S1 R14 /%PDMSUSER%\Test.dwg
  • [QUOTE=corrado;98641]Yes you can.
    You can even run a macro.
    See an example here below:
    $M/C:\AVEVA\Pdms12.0.SP6\full_dxf.mac
    LIEXEC    /Draft_DXF_LI    'DXFOUTR13'    CONFIGDATA    'full_dxf'    OUTPUTFILENAME    'C:\TEMP\TEst.DXF'
    Thank you, Mr Corrado
    How about scale? Do you know command line to change scale of drawing  before exporting to Autocad?
  • [QUOTE=pcngocquy;102683]Thank you, Mr Corrado
    Done!
    Its possible to configure scale from full_dxf.mac
