Get diameter of the section of a CYLI or a SNOUT in DRAW
  • I would like to put a label similar to "pipe end" on a hollow equipment in draw.  The 3D shape is a CYLI or a SNOUT.  It is easy to get the CYLI diameter, but the SNOUT needs to be calculated.  To avoid this calculation, is it possible to get in DRAW the 2D diameter of the cut SNOUT.  If the cutting plane is not perpendicular, is it possible the axis lenghts of the ellipse.
