• please waiting for me amoment i give you a macro it will help you to setup DESC for all SCTN a round 10 minus
  • please find the link bellow for macro
    http://macro-pml-pdms-e3d.com/
    you can refer this one
    $* Type 3 Annotation Defaults
      $* Annotation Description
      var !!CDANOTYP3 |Gridline|
      $* Rule(s) to define what items are dimensioned
      $* that are contained within the view box limits
      $* Element types
      var !!CDDIMTYP3[1]  |Sctn|
      $* Element rules
      var !!CDDIMRUL3[1]  |Description eq 'GRIDLINE COLUMN'|
    $* Type 3 dimension line controls
      $* flag for controlling display of dimension text (TRUE/FALSE)
      var !!CDDIMLEV3FLG   |TRUE|
    $* Type 3 projection line rules and text
      $* Dimension points to be copied from other TYPEs
      var !!CDDIMCOP3     ||
      $* border from side of view for dimension position
      var !!CDDIMSPAC3     |50mm|
      $* proj text rules for view side in North or South Directions
      $* rule where this pltx is to be applied
      var !!CDPL3NSRUL[1]   |Type eq 'SCTN'|
      $* pltx contents
      var !!CDPL3NSTEX[1]   |#FUNC(P-1:1)(C2:)|
      $* proj text rules for view side in East or West Directions
      var !!CDPL3EWRUL[1]   |Type eq 'SCTN'|
      $* pltx contents
      var !!CDPL3EWTEX[1]   |#FUNC(P-2:2)(C2:)|
      $* Type 3 dimension layer purpose
      var !!CDDIM3PURP    |ADC|
  • this macro will work in model module you can settup in model design and save work, then you get work at module draft then update.
    any problem post  on forum
    exactlly that code above is a part of [COLOR=#333333]the dra-genadp[/COLOR]
