Draft Module Text problem
  • Replies 22 replies
  • Subscribers 5 subscribers
  • Views 60 views
Text problem
standy
standy over 10 years ago
  • Han_BFY
    Han_BFY over 10 years ago
    As norm.. alert just information with few text.
    but I also hope answer from others..  if default alert can make that happen.
    cheers!!
  • standy
    [QUOTE=Han_BFY;95852]As norm.. alert just information with few text.
    cheers!!
    Yes, thank you anyway. waiting for answer.
  • Shrivallabha Sharad Redij
    Shrivallabha Sharad Redij over 10 years ago
    You may want to try:
    !!alert.message('This is what I want to print
    Something on second line
    And some more on third line!')
  • Han_BFY
    [QUOTE=Shrivallabha;96386]You may want to try:
    Thanks Shrivallabha.. that is what we looking for.. very helpful
  • Han_BFY
    looks so easy but .. never thought that.. :-)
  • standy
    Hi Shrivallabha,
    Thank you very much!! That is what I really want.
  • Mohammad Reza Sabzevariha
    Mohammad Reza Sabzevariha over 10 years ago
    Simply go to next line, PML is EZ :)
    Anyway, I saw it is already responded. Cheers
  • Reddeppa
    Reddeppa over 9 years ago
    can we capture/store  the ' (single quote) in string?
    Example
    !s = 'AAA' & ''' & 'BBB'  & '''
    $!s
    this should print  AAA'BBB'
    regards,
  • Pedro Valadares
    Pedro Valadares over 9 years ago
    [QUOTE=Goals;99498]can we capture/store  the ' (single quote) in string?
    Example
    $!s
    regards,
    Yes, you can use the following method:
    !s = 'AAA' & |'| & 'BBB' & |'|
    or just
    !s = |AAA'BBB'|
    Then query the resulting string with
    q var !s
    instead of
    $!s
  • Reddeppa
    Thanks Dude.
    However the string I have to use in between the command line statement in PML. where we could only use $!s, Q var !s is not allowed as mentioned below . please advice.
    !s = |'c:\temp\test.txt'|
    OutputFile $!s
    Result should print/execute  in command line
    OutputFile 'c:\temptest.txt'
    regards,
