oh yea that's not the problem. the whole reason I use glabs is to keep the material table live.
So that if I change a beam in design the it will automatically change the values in my table as well.
Now if I do the math in excel I need to always run it through excel anyway and that leaves
psize and all the other attributes useless in draft.
I see your point and understand the problem now. I'm not sure if there is an easy solution for this... Perhaps you could search this forum for material table. There might be some custom material tables members have done, that may give you tips.
I don't think I can help you further, good luck! :)
