how are you, myself satender i dont know the new bolting method.
can anyone please explain to me actually its very important to me because my client want bolting from new method only.
please dear help me client is putting a lot of pressure for for this.
Hello experts also tell me can i use old bolting for few components in place of new bolting method.
NEW bolting method calculates its BOLT length. For example, Flange1 Thk + Gasket Thk + Flange2 Thk + ( 2 x Nut Height ) + Extra length
Basically these values are stored in
Flange Thickness - From Bthickness of BLRFARRAY of CATREF (BTSE or BLTP Element)
Gasket Thickness - Face to Face of Gasket
Nut height - BITLENGTH of BLTREF of Bolt Spec (SBOL Element)
Extra length - XTRALENGTH of BLTREF of Bolt Spec (SBOL Element)
these can all be found in User Guide. Please take time to read as this is a critical task.
please sir its very important i have created a component in catalogue in pre existing project,
i have put the bolting on that component by using new bolting method but i am not able to get bolting in isometrics.
[QUOTE=sduanbm;19214]Is there some one that can explain the different types of BTYP?
MACH = machine bolts => bolt with nut and washer
STUD = Stud bolt => stud bolt with nuts and washers
CAP = Cap screw => only cap screw
And now to the Quest
JACK = Jacking screw => is the for lifting devise
TAP = Tapped holes => what is this? Taped holes aren't that what the CAP is for?
Thanks
:support:
Hi there
I am having a curious issue while trying to get cap screws to run on a valve connected to a flange.
The total amount of bolts should be 12-off
I am getting 12-off bolts and 12-off cap screws displaying on the isometric
the flange has 12 off bolts m20 dia with the btype as Bolt
the valve has 12 off bolts m20 dia with the btype of Cap
when the isometric runs i get 12 off cap screws of a shorter length, that i require and 12 standard bolts that are slightly longer based on the rpro flth attribute that i do not require.
Why am i getting both cap bolts and standard bolts on the connection/joint when the cap bolt is set as 12
The valve btype is cap for all 12 bltp
In essence i am getting the double quantity of bolts at the joints
Any ideas what is causing this and does anyone have a solution
Mark, bolt calculation is quite complex and it is difficult to help you without accessing your catalogue and specification configuration.
I would suggest to contact Aveva UK so they can connect remotely to you machine and solve your issue
Kindest regards
Corrado
