PDMS "Lessons Learned"
  • PDMS "Lessons Learned"
Installation & Upgrades hull transfer macro
  • Replies 26 replies
  • Views 31 views
hull transfer macro
gaizkaemin
gaizkaemin over 16 years ago
  • gaizkaemin
    ı know it codooaustin if u do not have an idea how to write macro which ı need please do not take my time
  • JMM
    JMM over 16 years ago
    WHOA! A lot of "inference" is lost in txt but your attitude clearly isn't.
  • Neil Dryden
    Neil Dryden over 16 years ago
    That's certainly a novel way of coaxing help from someone..
  • avwf_BenDover414019
    avwf_BenDover414019 over 16 years ago
    You can also check Tribon Forum at www.mbmproject.com. You could get help from there.
    In general, Vantage Marine is not widely used, I would consider it a "transition" product, where Tribon and PDMS were put together for the first time. One of the issues is, as you know, that Hull and Outfit have separate databases, and that's why you have to do the transfer to keepthem in sync.
    By the way, what was the reason you are using Vantage Marine instead of Tribon M3? Do you have any PDMS experts who could help you out with programming to automate the transfer?
  • gaizkaemin
    hello ben dover;
    thanks for your attention first as ı said my company using vantage marine 11.6 ı take the train from aveva also but not pml and pml2 ı am the admin in my company but my porblem is to transfer hull from planar hull module to pdms every day it takes soo much time to transfer all the ship that is the reason ı wanna find a macro like that can u help me my friend??
  • Miika
    Miika over 16 years ago
    It is over year ago when I tried Vm 11.6. It is not clear for me what kind of macro you want. Do you want macro which automatically transfer data before you come to work. Or macro so that you don't need to select commands from menus.
  • gaizkaemin
    hello mkoskinen;
    ı want a macro when in planar hull modul user did something at the same time in vantagemarine outfitting updates automatically can u help me on this topic??
  • Miika
    Sorry , I cannot do that. Currently I only have customers licenses so can't do this. I can help you if you have something problems with pml but I have not time and license to help you from nothing.
    These problems are solved at Marine 12 with savework and getwork so at next project this shouldn't be problem.
  • gaizkaemin
    thanks for your help mckoskinen ı want to ask u a nother question when in isodraft module how can ı write a revision macro ı want to write revision note to template do u know??
  • Miika
    Hi
    Revision in Isodraft with pml is not easy to me.
    Only a quess: Have to add some attas to design and it appears to isodraft when  needed. Maybe some experts can answer to your question.
