• могу только посоветовать открыть командную строку (Command window) в PDMS, вбить команду $R102 и попробовать после этого выполнить свой макрос. в командной строке отобразится всё происходящее. А вы уже покажете результат нам.
    Вот результат:
    $R102
    [0]
    $m d:\aveva\1\bolttool.pmlfrm
    [2] $m d:\aveva\1\bolttool.pmlfrm
    -> ENTER [1] d:\aveva\1\bolttool.pmlfrm
    [1] setup form !!BOLTTOOL
    [2]       title 'Bolt tool'
    [4]       frame .frame1 'Pipe List' at x0 ymax
    [5] ($)
    [12]          button .add   at x1 ymax 'Add CE'  tooltip 'Add ce to list' callback |!this.add()|
    [13]          button .addmem 'Add CE mem' tooltip 'Add ce member to list' callback |!this.addmem()|
    [14]          button .remove 'Remove' tooltip 'Remove selection in list' callback |!this.remove()|
    [15]          button .removeall 'Remove All' tooltip 'Empty list' callback |!this.removeall()|
    [16]           (          $)
    [21]          list .list at x1 ymax+0.2  callback |!this.listpipe()| width 40 height 5
    [23]          button .save   'Save List' at x1 ymax tooltip 'Save obstruction list' callback |!this.save()|
    [24]          button .load   'Load List' tooltip 'Load obstruction list' callback |!this.load()|
    [25]          text .savefile 'File name' at x1 ymax+0.2 width 30 is string
    [26]          toggle .boltmodel 'Model Bolt' at x1 ymax+0.2
    [27]          toggle .boltcheck 'Bolt MTOC Check'
    [28]          toggle .Mtocheck 'Mto' at x1 ymax+0.2
    [29]          toggle .namecheck 'DrawMto with name'
    [30]          toggle .speccheck 'Mto With Spec'
    [31]       exit
    [35]       button .test  'report&model' at x0 ymax+0.5  tooltip 'Bolt report and model bolt' backg 5 callback |!this.test()|
    [36]       button .apply  'Del Bolt' tooltip 'delete bolt model' backg 2 callback |!this.apply()|
    [37]       button .cancel 'Cancel'   cancel
    [40] exit
    [45] define method .bolttool()
    [53] define method .checkconn(!names is string) is string
    [72] define method .flanht(!bran is string,!head is string) is string
    [148] define method .getflan() is array
    [471] define method .checkflan(!flan is array) is array
    [494] define method .mto()
    [657] define method .test()
    [693] define method .boltlength(!len is real,!flan is string,!boltm is string) is real
    [782] define method .modelbolt(!flan is string,!dis is real,!blength is real)
    [843] define method .subequi(!bolt is string,!len is real,!dis is real,!bore is string,!fthick is string,!sthick is string) is string
    [895] define method .getod(!bore is string) is string
    [959] define method .outputerr(!err is string)
    [967] define method .oldmethod(!flan is string, !num is string , !spec is string,!btype is string) is array
    [1130] define method .newmethod(!flan is string, !num is string,!bspec is string ,!blrf is string) is array
    [1217] define method .getthick(!flan is string, !num is string ) is array
    [1333] define method .getbolt(!flan is string) is string
    [1369] define method .breport(!flan is array)
    [1388] define method .save()
    [1398] define method .load()
    [1410] define method .listpipe()
    [1421] define method .add()
    [1443] define method .addmem()
    [1470] define method .remove()
    [1480] define method .removeall()
    [1487] define method .apply()
    <-  EXIT [1] d:\aveva\1\bolttool.pmlfrm
  • Hi Vladimir_P,
    Is your bolttool.pmlfrm working on PDMS v12?
    I am interested on this too.
    Thank you.
