Batch trend project sample
Sample application to create Batch files, where you will be able to create several files with the name you enter on text object. Basically,the project was developed using the options from advanced button on trend tasks.
  • Hi Marcos,
    thank you first for your application.
    As far as I have understood how you put on the batch file.
    Would it be possible that you could send me a sample application, as I re-read the batch file back to the surface and how I can make the hst file a .txt or .csv file?
    I'm trying to create an application in which you stratet a batch recording with one touch and terminated. These batch files should also be provided with a time stamp.
    About the register function, I will then create a report.
    Thank you once before in advance and wish him a pleasant day.
    With best regards
