Title: Run a Windows Batch File to Output to Project Folder
Platforms: Windows, Windows Embedded
Version: v8.1 SP0 P0, but should work in v7.0 and up
This sample application demonstrates calling a batch file by passing a parameter to it that determines the full path and file name the batch file is to write to.
The batch file is called from a Procedure, and the procedure can be executed by a button on the screen or through a script worksheet.
