Load .NET Control
I want to load custom .NET Control (built using v4.0 .NET Framework), but came up with error message
This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded
How to solve this? I am using Indusoft v8.
Regards
  • Hi, guys.
    I'm also using .net 4, encountering this problem?
    Any suggestion?
    Regards
    Ramin Zarei
  • From the Help Manual (search for ".NET" and see the topic .NET Control Object):
    In order to be placed in a project screen, a component must meet the following requirements:
    - It must be built with .NET Framework version 2.0, 3.0, or 3.5. Components that have been built with .NET Framework 4.0 or later are not supported.
    - It must be designed using Windows Forms (WinForms) rather than Windows Presentation Foundation (WPF). Components that have been designed using WPF are not supported. You can use third-party development tools such as Visual Studio to "wrap" a WPF-based component, however, so that it has WinForms control layer and therefore can be used in InduSoft Web Studio.
    - It must be designed as a User Control — that is, it must extend the System.Windows.Forms.UserControl class.
    - The DataGrid and DataGridView controls are not supported in any case. As an alternative, use InduSoft Web Studio's own Grid object.
    Richard Clark
    InduSoft TMS
  • Ola estou tentando instalar a versao educacional 8 e sempre apresenta erro 1603 -e informa pra ver ajuda do msi.chm...alguem pode me ajudar ???
  • Prezado Marcio,
    Primeiramente gostaria de agradecer o interesse em utilizar o InduSoft Web Studio Educacional e pedir desculpas pelo contratempo enfrentado. Para que possamos lhe ajudar, peço que nos envie através do email educacional@indusoft.com.br maiores detalhes do erro encontrado, assim como o Site Code gerado pelo módulo de registro em seu computador. Utilizando este código podermos ajudá-lo de maneira mais eficiente.
    Ficamos no aguardo de seu email.
    Paulo Guerra
    InduSoft Educacional
  • Buneas tardes, tenía instalado el Indusoft 8.1 SP1, al tratar de instalar el SP5 me sale el error o 1603 y me dice qye busque ayuda en msi.chm (MSDN). Alguien ha tenido este mismo inconveniente?
