Barcode Label Printer
What brand of label printer have you had good success with for printing barcodes from InduSoft? I have an application where I would like to print labels generated by InduSoft. Basically all I need on the label is a number and the barcode. It would be like a 2x3 self adhesive label.
  • Hi,
    I suggest that you look for printer that supports serial communication port RS-232 / RS-485
    Then, you can use the "TxRx" Indusoft communication driver to communicate with the printer.
    This driver allow you to freely send whatever data you want over serial port.
    The communication protocol syntax of the printer should be explained in printer manual.
  • Hi Bryant.
    We use Zebra printers with Indusoft for printing product weight tags, with barcodes and a variety of text sizes.
    The Zebra ZPL printer language is well documented.
    In our application we do not find it necessary to use an Indusoft driver.
    - The Zebra printer (either serial RS232, or network connected) is configured as a generic/text only printer for the PC/server.
    - The Indusoft application writes the needed ZPL commands and text to be printed to a text file using calls to the Indusoft FileWrite() function.
    - The resulting file is then printed using a batch file (see batch file commands below) called from the Indusoft WinExec() function.
    NET USE lpt1 /delete
    NET USE lpt1: \\%COMPUTERNAME%\zebra /PERSISTENT:YES
    print /D:lpt1 <path to file>\<filename>
    This method works perfectly for us, and avoids consuming an Indusoft driver.
    However, as mentioned in the earlier response, you can also write directly to the printer from Indusoft if this is better for your application.
    This should also be possible using either a serial or network connected printer.
    Both would use the Indusoft TXRX driver.
    For a networked printer the TXRX driver setting would be configured for TCP/IP encapsulation.
    Hope this is of some help.
    Regards,
    Greg Shearer
  • I will suggest you go with the canon printer I know that canon is not a label printer but if you install a third-party software then it will be very easy to print the label, I also doing that process but now I have faced some problem blem that my [url=https://canonsupportnumber.org/how-to-fix-canon-printer-printing-blank-pages/]canon printer printing blank pages [/url]. I change the printer cartridge but it not work. I searched many websites and could not get a proper solution. If anyone has any idea about that problem then suggest to me about that printer problem.
