WIN 10 IOT ENTERPRISE
Hello,
I would like to know, if there are any limitation using Win 10 IoT enterprise with IWS V8.1 SP4. Will the system perform as it would be, if I had WIn 10 Pro platform? Of course the runtime license will be a regular Windows Runtime License (ex. IND16520RT).
Thanks in advance.
Elias Doukas
  • Hello,
    This is my understanding of the different versions of Windows 10
    Standard vs. IoT (IoT Can be LTSC or SAC)
    - Licensing
    - IoT - Fixed Hardware (or limited to a certain sub-set)
    LTSC(LTSB) vs. SAC(CB, CBB)
    - LTSB - No MS Edge, No MS Store (or Apps), No Cortana
    - LTSB - Longer intervals between updates
    - LTSB - Option to not update (or significantly delay update)
    - LTSB - Does not support future processors (need to use to latest version to support latest processors)
    Enterprise vs. Pro
    - Enterprise is a notch above pro and geared more towards IT pros and how systems are deployed and maintained
    InduSoft specific notes:
    InduSoft can be deployed as Full Runtime OR as EmbeddedView on Windows 10 IoT LTSB systems.
