I am running Indusoft on a Beckhoff CX5130 PC (Embedded pc running Windows 10 Pro). While running my project on my laptop (also Windows 10 pro) the pop up keyboad/keypads function as intended for input enabled fields. However, when I run this project from the embedded system the keypads do not work, I am unable to enter data in the fields. If I disable the virtual keyboard from the Project/Viewer settings the Windows keyboard pops up and I can enter data. While this works, I prefer the Indusoft keyboard/Keypads for simplicity and these are what are used on our other machines.
Any thoughts on why the keyboard/keypad does not come up? It has to be a configuration issue somewhere.
