Grid with static and dynamic data
Hi,
I need to make a grid like an attached file what is very simple but the data in description field are fix and the data in value field should read from tag!
E.g. Imagine I have 3 machine and I want to monitor their uptime / downtime like :
MachineName Uptime downtime
Machine A Value Value
Machine B Value Value
Machine C Value Value
If I use class tag , I have to make tag also for machine name what is fix.
May be the solution is to make a fix value for the mentioned tag! but I dont know how to do this!
How can I make this kind of grid?!
Thanks
  • Use a class tag as follows
    Define a class called 'MyGrid' with the following members 'Name', 'DownTime' and 'UpTime'
    Define a new project tag called 'GridData' with the data type 'MyGrid'
    In your Startup Script add the following
    $GridData[0].Name = "Machine A"
    $GridData[1].Name = "Machine B"
    $GridData[2].Name = "Machine C"
  • [quote]
    Posted By Norman E on 05 Dec 2019 09:28 AM
    [/quote]
    Thank you:)
  • Hi,
    Thanks
  • When using a text file as the data source, you can only use tags for the column labels. Not the data in the text file.
  • Hi,
    Thank you for fast reply.
    however I do not agree to surrender in front of the goal,
    Could you advise which option could be used to obtain a grid with all types of Alarms for the device like a Temperature transmiter?
    Thank you
  • 1. If your goal is to be able to display live data, or edit tag values, then the easiest option would be using a class tag. (negative: uses a lot of tags)
    2. If you just want to display static information, then you could use the report function (or vbscript file functions) to generate a text file with the data you wish to display in the grid. (negative: more difficult to implement)
    3. If you have database experience, that option may offer the most flexibility. (negative: most difficult to implement)
    4. Another possibility is using custom properties and .mne files. (this is what I use for faceplates)
    You could use option 2 to display the data and option 4 to edit the data.
  • Hi,
    Thanks
  • Hi,
    Thanks
  • [quote]
    [/quote]
    Thank you Norman E for the above comment.
    It was very helpful for my project also, regarding column Label.
