Compliance with 21 CFR
Hello sir,
As per the 21 CFR, no unauthorized user like operator and Supervisor can access windows.
sir I am using Indusoft V8.0 SP2 with Windows 10 OS Touch screen IPC. I have disable Windows task manager for the guest, operator and also for supervisor from SCADA which is disable to user to access windows key. but same function is not working when i slide screen from left(Also untick all the access from user group policy). while sliding it shows all the running application on screen so even if as a guest i can access windows function...
Please help me for the above problem.
