Node Name - Name of the node. It can be any string up to 64 characters. This name must be unique; it cannot be reused by other objects. oid - Relative object identifier. This OID is appended to the root OID to make the real OID for the table. trigger - Name of the tag that triggers the trap. Every time the value of this tag changes, a new trap is generated; columns - Number of values returned by the trap. column[n].tag - The name of the tag returned as value n. column[n].type - The type of data in returned as value n. column[n].oid - OID of data in returned as value n.
Example:
[trap1] item = trap OID = 1.4 trigger = second Columns = 2 Column[1].tag = date Column[1].type = string Column[1].oid = 1.5.1 Column[2].tag = time Column[2].type = String Column[2].oid = 1.5.2
This example configures a trap that is generated every time the tag “second” changes. It returns 2 string values, from the tags “date” and “time”.
