Hello,
I am trying to set up a trial version of a SCADA system as a demonstration for e potential client.
However, I would like to directly open a certain screen after the user logs on- i.e. I want to skip the Alarm/Process Values/Trend
selection. Further, I do not want to give the customer the option to randomly open all screens the project contains.
I looked at the Indusft 8.0 technical reference from here:
http://www.indusoft.com/Portals/0/PDF/Documentation/IWS%20v8.0%20Technical%20Reference%20(LT).pdf
Page 689 explains how this can be done using a kind of long and convoluted address, for example
https://scada.ourcompany.com/IWS80.0.0/index.html?screen=Animations&user=Operator112&password=eWi28fb2
However, can you advise if there is an easier way t do this?
Is there a way to set up the system that after typing, for example 176.3.134.45/ma the user will first see the logon menu
and the will go directly to the first start-up screen, just as if they were looking at the Indusoft Viewer?
Thanks for the help in advance and best regards,
Alex
