Writing text file with tab coluns
I basically want to create a text file with a column separated by tab like this:
Column 1 <tab> Column 2
123 <tab> 43534
My data is coming from a SQL database. I tried this code:
Function teste
Dim sql, numCur, numRows, row, txt
sql = "SELECT * FROM Paradas"
numCur=$DBCursorOpenSQL("DB", sql)
numRows=$DBCursorRowCount(numCur)
If numRows > 0 Then
For row=1 To numRows
txt = $DBCursorGetValue(numCur, "ID")
txt = txt & vbTab & $Format("#.###",$DBCursorGetValue(numCur, "Qtd_Horas"))
$FileWrite("C:\Relatorios\teste.txt", txt,1)
$DBCursorNext(numCur)
Next
End If
$DBCursorClose(numCur)
End Function
Unfortunately, it doesn’t work. But if I change the code for this:
Function teste
If numRows > 0 Then
txt = txt & "," & $Format("#.###",$DBCursorGetValue(numCur, "Qtd_Horas"))
Next
End If
End Function
Now the code is working, but the result is:
Column 1, Column 2
123, 43534
I tried this too, but it doesn’t work again.
Function teste
If numRows > 0 Then
txt = txt & $Asc2Str(9) & $Format("#.###",$DBCursorGetValue(numCur, "Qtd_Horas"))
Next
End If
End Function
If anyone helps me I will enjoy it.
  • *** Apparently the FileWrite function does not like the tab character.
    *** Add the following lines to the beginning of your function. Use OpenTextFile instead of CreateTextFile to append to a file.
    Dim MyFSO, MyStream
    Set MyFSO = CreateObject("Scripting.FileSystemObject")
    Set MyStream = MyFSO.CreateTextFile("C:\Relatorios\teste.txt", True, False)
    *** Replace $FileWrite(… with the following
    MyStream.WriteLine (txt)
    *** Add the following to the end of your function
    MyStream.Close
    Set MyStream = Nothing
    Set MyFSO = Nothing
