Hello,
I am using the Import Wizard CSV Database to import the tags from a csv file (csv_file.png).
It works perfectly fine except for the "Web Data" column (Scope) that does not read neither "Server" nor "Local". (CSV_database.png).
The result is that I obtain two tags but with the default value in the "Scope" column, which is "Local". (result1.png and result2.png).
Does anyone know how can I make InduSoft read the correct value of Web Data?
Thank you in advance.
