Tabular data in RTF Report?
I am attempting to create a report that outputs various statistics for analog feedback values. Ideally, the values should be displayed in tabular format - if there is a way to create a table using RTF, that would be best! If tables don't work, then does anyone have a good method for formatting an RTF report to yield organized columns of data? Currently, I have checked the "Lock Value into the [Tag/Exp] length" option and created tags with names with the exact length that I need. I create the report by setting these tags to real values and then appending a new row to the file. This is cumbersome, prone to errors and also requires using Courier New font which I don't want. Does anyone have a better way of making an RTF report display organized columns?
