The above scripts work and i can get the some information of an ip camera. but now i have few ip camera and plan use a text-box to type in the ip address and when i click $checkconnection button, i expect the ipaddress to be loaded into the snmp straddress,but i always get error. the snmp cant work. Above works because i hard code the ip address.
So how to syntactically write a script that will automatically replace the ip address into the snmpGet function as the IP address is typed in the textboxtag.
e.g as below:
$SnmpGet("how to load the ipaddress here!!","Public",".1.3.6.1.2.1.1.1.0","ConnectionOK")
[quote] Posted By Norman E on 08 Jul 2020 02:00 PM Try "public" instead of "Public"
What error number is returned?
The following should work assuming textboxtag is a string tag $errorTagstr = $SnmpGet($textboxtag,"public",".1.3.6.1.2.1.1.1.0","ConnectionOK") [/quote]
i was getting a -5 (get operations failed) after used the above method, and it worked after i change Public to public, Thank you.
previously i did try changing Public to public but maybe because some confusion it didn't work.
