Looking for additional training videos or tutorials
My Web Studio project will be running on a panel PC along with some other Windows applications. I want my Web Studio project to have the same Windows look and feel (e.g. minimize, maximize, exit buttons in the upper right boarder) as the other Windows applications. I watched one tutorial from the V7.1 training series on Screen Groups. It was very informative, but I got the feeling the end product would be running by itself on a dedicated unit.
Are there any other tutorials I can watch to steer me in the right direction? Or will the v7.1 videos get me there if I say with them long enough?
  • First off, you will need to use the full version (i.e. Windows not Embedded) to accomplish this.
    All of the settings you mentioned are in the 'Viewer' settings under the 'Project' tab.
  • Thanks Norman.
    Just so I'm clear, for my Web Studio project to have windows look and feel on the target, my target needs to be running a standard Windows OS and not one of their Embedded OS's?
  • In Indusoft, under the 'Project' tab there is a 'Target System' setting. You need to select an option under 'Windows' not under 'Embedded'.
    InduSoft allows you to use either one depending on the target. A couple of OSs can use either one, depending on how InduSoft is installed. Windows Embedded Standard and Windows 10 IoT Enterprise can be setup to run as Windows or Embedded. This determines what license you need to purchase. You can configure a project as Embedded and run it on a Windows system but you can not configure a system as Windows and use it on an Embedded system.
    In Short:
    Make sure you have a Standard Windows OS (not Compact or CE), configure the InduSoft 'Target System' as 'Windows' and use a 'Full Runtime' license and you will be OK.
  • Thanks again Norman. I believe I ordered the correct runtime license for my target then. I purchased the full runtime license.
