Login with blank password inside domain
In our project we have Indusoft Web Studio 8.1 SP5 and Windows 10 as the operating system. We use Secure Viewer client for viewing the application. Indusoft is connected to company domain with LDAP.
The problem is that all domain users are able to login with blank password in addition to their correct password. Invalid passwords do not work, however. The issue appears only when running in Secure Viewer, if the application is started from Indusoft's development environment, there is no problem. The issue appears only with LDAP, if we change to local security system, everything works even in Secure Viewer.
It seems that all users are behaving as if they are Guest users. However, a guest user has been defined in the AD and all other users have their owns groups with different rights.
Is there a known solution for this kind of problem? What would you suggest that we test to solve the issue? We cannot reproduce the problem in our company AD, nor have we ever seen it in any other project.
Best regards,
Atro Karvinen
