Beckhoff Driver for Windows CE not starting on the target - also manual start failed - i tried now for hours to get it running ... hmpf .... using IWS2020 ......
Is Indusoft running on the Beckhoff CE device? Yes
Is Indusoft running on a separate PC? no - but from the development pc i get connection. if i start the project on the development pc i get connection and everything working - if i start the iws runtime on the target com driver did not start ....
Was it running before and just stopped or has it never worked? never worked
TwinCAT 2 or 3? TwinCat 2
Is the Beckhoff ADS driver not loading on the target or is the Indusoft TwinCAT (TWCAT) driver not starting? Indusoft TWCAT Communication Driver not starting
Is the device discoverable (Broadcast Search) from a PC with TwinCAT? yes
If it is a problem with the Beckhoff CE device you should be able to re-image it. I tried with 2 Displays ....
Check your AMS NetIDs, IP addresses. Check firewall. I did !
