Invalid array index
I have a Beckhoff Twincat project for PLC and Indusoft IWS version 8.1 for HMI. I can compile and restart the Twincat project fine, but once the HMI starts running, I get these errors as a result of array indexing in HMI. I double check everywhere to make sure the array indexing is correct (no space or out of range reference within the index of the array for HMI) but still getting this error. On IWS indusoft the log shows every thing is Fine.
Is a patch needed, if not, how can I debug the issue and resolve it?. Thank you.
Farideh
