Missing leading zero when using format instruction
Hi guys!
I have problems showing real values comming from an Omron PLC (CJ1M) so I have created an integer value to represent the value in indusoft using the format instruction ##,##. How ever, when the value drops below 100 (ex. 99) then the value is 99 and not 0,99. Is there any way to force leading zeros?
Thanks,
Jan
