Windoww Placement on Powerup
I am running v7.1 on a Beckhoff CX1020 with XP embedded. I am unable to get the application to start up with the application window properly centered on the screen. The window is offset down and to the right. Is there any way to actively force the placement of the window?
  • Hi,
    In the indusoft environment when you edit your project you can right click on the opened screen, and click "screen atributes" this will give you a window where you can set the window location on the screen ( Top and Left location ).
    You can also edit if the project should be maximized on startup under the "Project settings" -> "viewer"
    hope it helps
