I have some NO momentary push buttons in my application that will set the tag high but wont reset the tag low after the button is release.
On the command line for the button the tag is set while down and reset while up. Normally the push button works fine, but the odd time, maybe once every two weeks, the tag in the PLC remains high. The tag is only referenced in the HMI so I know there isnt anything in the PLC latching it. The PLC is TwinCat and I am using 7.1 for Indusoft. Any ideas?
