I searched the forums and the manual but didn't quite see what I was looking for.
I have a valve class, and a valve instance of that class called DO01.
I deployed a project symbol for the valve instance, and tied my custom property [#TagName:] to the instance DO01->Name so that the valve does what it is supposed to.
When I click on the valve, I use VBScript to open a new screen for a faceplate that can be used to turn that valve on or off.
Here is the problem: For my VBScript to work, I have to hardcode the instance name not only in the custom property (which is fine), but I also have to hardcode the instance name within the VBScript itself (see below).
$DO_pointer = "DO01"
$Open("as_DO_faceplate",1, -1, -1, -1, 0, 10, "")
What I want to do, is to access the #TagName: custom property which I already configured at the instance level from VBScript so that I don't have to hardcode the instance name twice.
It seems like this must be possible, but I cant get it to work and could use some help.
Best regards,
Joel
