Quering Database Table with mroe than 16000 rows
Should you be facing troubles to query a database table containing more than 16000 rows on IWS, here is an example of a VB function that can be used. This function, when placed, for instance, under Main Procedures and called passing the Table name, returns the total number of rows (even if the table is bigger than 16000 rows).
Function iDBGetTotalRows(strTable)
Dim i, numCur, sql, rows, rowsTotal
'select first 16000 lines
sql = "SELECT * FROM (SELECT *, ROW_NUMBER() OVER (ORDER BY ID) as RowNum FROM " & strTable & ") seq WHERE seq.RowNum <= 16000"
numCur = $DBCursorOpenSQL("DB1", sql)
rows = $DBCursorRowCount(numCur)
$DBCursorClose(numCur)
rowsTotal = rows
Do While rows>=16000
'select next 16000 lines
sql = "SELECT * FROM (SELECT *, ROW_NUMBER() OVER (ORDER BY ID) as RowNum FROM " & strTable & ") seq WHERE seq.RowNum > " & rowsTotal
rowsTotal = rowsTotal + rows
Loop
iDBGetTotalRows = rowsTotal
End Function
Enjoy!
Greets,
Ricardo Marroni
  • Here the same function but with two additional fields for the database connection name and the order field, so you can pass any valid field of your table.
    Function iDBGetTotalRows(strDB, strTable, strOrderField)
    sql = "SELECT * FROM (SELECT *, ROW_NUMBER() OVER (ORDER BY " & strOrderField &_
    ") as RowNum FROM " & strTable & ") seq WHERE seq.RowNum <= 16000"
    numCur = $DBCursorOpenSQL(strDB, sql)
    rowsTotal = rows
    ") as RowNum FROM " & strTable & ") seq WHERE seq.RowNum > " & rowsTotal
    Loop
    End Function
    This function can be called, for instance, from a VBscript on a command button. E.g.:
    Dim tableRows
    tableRows = iDBGetTotalRows("DB1", "Table_1", "ID")
    MsgBox "The database table has " & tableRows & " rows."
    Greets,
    Ricardo Marroni
