Database Spy
This document describes using the local and remote Database Spy tool in both the development and runtime environments.
  • I am using this to monitor tags I am using in the project, found an issue where the data table in the PLC =0 yet the tag in this shows the value = 1 and the screen also reflects = 1 on the display object.
    Is this not updated all the time? Yes it is set to Continuous
    What could cause this not to update automatically?
    Stan
  • Stan, is your tag set to Server or Local scope? You can view this property in the Tags Database>Datasheet View.
    Btw, it would be better if you can repost your question in the Technical Questions subforum as this subforum is not for troubleshooting.
