A Spectacle blind is used to block the path of the fluid when it is intended to block the path for a relatively longer time and to prevent any leakage. Spade and Spacers are also used for the same purpose but for larger sizes. The Spade blocks the path whereas the Spacer fill-in the space when the Spade is removed
