General
General
Members Chat Area! Piping Info - Choke Valve
  • Replies 2 replies
  • Subscribers 2 subscribers
  • Views 5 views
Ganesh Ramakrishnan
Ganesh Ramakrishnan over 18 years ago
  • Ganesh Ramakrishnan
    Choke Valve
    A choke valve is a valve that changes the flow rate of the fluid at very high operating pressures with only a slight pressure drop. It is also used when changing the conditions of a line from high pressure, high flow rate to a lower pressure, lower flow rate. It is capable of handling erosive fluids with sand and grit. This valve is typically used in wellheads before the fluid is brought to the process area.
    :smoke:
  • Admin
    Admin over 9 years ago
    thank you so much for your sharing
