General
General
Members Chat Area! Commodity Code!!!
  • Replies 10 replies
  • Subscribers 2 subscribers
  • Views 28 views
Commodity Code!!!
aaaaaa
aaaaaa over 17 years ago
  • aaaaaa
    Hi My Friends
    Have You Got Any Procedure Or Instruction For Making  Commonity Code For Piping Component???
    Please Help Me!!
    Your Faithfully
  • aaaaaa
    Commonity=commodity
  • avwf_de_ding
    avwf_de_ding over 17 years ago
    This is a loaded question.
    How does someone reinvent the English alphabet, ASCII code?
    With that said, you have to consider GTYP, Bore size(most time two fields, but can be up to 3 parameters for Cross type components), vendor...
    And then you may come up with a naming convention like CRVBSTFF for example, CR=Crane (vendor name) VB= Valve Ball, ST = styp, full bore or reduced bore, FF = DN 50 or 2in.
    Of course, just as you think 8 digits is enough for your SCOM naming convention, you will encounter a case where 10 digits maybe requested, so that means you have to revamp all your existing naming convention...
    Good luck!
  • aaaaaa
    de_ding
    Thank You my friend But I need a present instruction (which have been written ) that Completely cover All component!!!
  • Admin
    Admin over 9 years ago
    as we know for commodity code is job that handled by material engineer
  • Admin
    But we can make formula for item code of material in pdms
  • Admin
    For Valve Stock Code :
    [ATTACH=CONFIG]9158[/ATTACH]
  • Admin
    For Flange Stock Code :
    [ATTACH=CONFIG]9159[/ATTACH]
  • Admin
    For Gasket Stock Code :
    [ATTACH=CONFIG]9160[/ATTACH]
  • Admin
    For Blind & Spades Stock Code :
    [ATTACH=CONFIG]9161[/ATTACH]
