General
General
Members Chat Area! U-Bolts Supports for Circular HVAC
  • Replies 7 replies
  • Subscribers 2 subscribers
  • Views 3 views
avwf_ssendhilkumar903948
avwf_ssendhilkumar903948 over 16 years ago
  • Admin
    Admin over 16 years ago
    Hi
    Have you looked at 'Hangers & Supports' module, the only other option I know of is MDS (Multi Discipline Supports).
    As a last result you could make the supports in Equipment and copy thro'
  • avwf_ssendhilkumar903948
    Can we create supports for HVAC DUCTS, for example, in my case, I have a circular hvac as STRT with dia of 660 mm, I just want to create a U-Bolt Supports with flat bar of 100x6 mm around the  HVAC, Can any one help me in this regard.
    Thanks
    Sendhilkumar
  • Cody Austin
    Cody Austin over 16 years ago
    I would use MDS as you can automatically generate Support Drawings and your supports will automatically be shown on ISO's etc.
    Thank u very much for ur valuable comments, wil try and let u no...........
    i tried in MDS only, but i couldnt get the U-bolt for 660 dia , STRT, THE MAIN PROB IS, WN V TRY TO MAKE A SUPPORT IT ASSIST TO SELECT ANY TUBE OR PIPE , BUT MINE ONE IS STRT SINCE I MADE IN HVAC COMPONENTS
  • Raymond Metselaar
    Raymond Metselaar over 16 years ago
    Then you will have to model the support as equipment.
    Hth,
  • Cody Austin
    Are you sure you are creating HVAC supports and not Pipe supports?
