General
General
Members Chat Area! usage of various module
  • Replies 9 replies
  • Subscribers 2 subscribers
  • Views 15 views
Admin
Admin over 15 years ago
  • Admin
    dear all,
    I am new for pdms.I wants to know , what is the usage of various module (design module,draft,specon,paragon,admin,global,bolting)
  • Cody Austin
    Cody Austin over 15 years ago
    Please either read the manuals to learn, or take a training course.
  • Raymond Metselaar
    Raymond Metselaar over 15 years ago
    These are modules of PDMS:
    design ,draft,specon,paragon,and admin.
    Global is way to share projects over multiple locations in the world (hence teh name global)
    Bolting is the way piping is connected. So not a module.
    Hth,
  • Admin
    at first you must learn design module (to creating 3d model) so learn draft to create draft from model after to be enough expert learn other module
    I disagree, if you are a structural designer then learn the structural module, if piping designer learn piping module, if mechanical designer learn equipment module and so on. All designers are recommended to learn Draft, leave specon, procon to the administrators. Remember pdms is to be used by designers not modellers! otherwise how do you know what you are designing??
  • DAVOUD BAHRI
    DAVOUD BAHRI over 15 years ago
  • DAVOUD BAHRI
    yes , of course , but design is a generally module and he could select needed section after select design module
  • Admin
    Admin over 9 years ago
    Design Module is module is used to create design
    Draft Module is module is used generate and create drawing 2D
    Isodraft Module is module is used to generate isometric drawing
    Spooler Module is module is used to create pipe spool
  • Admin
    Specon Module is module is used to load spec
    Lexicon Module is  module is used to create attribute
    Propcon Module is  module is used to create properties like weight, etc
  • Admin
    Admin Module is module is used for administrator for set project like create team, user, mdb, ACR, etc
    Paragon Moduel is module for creating catalogue, etc.
