Is it possible to prepare User defined end connections in PDMS...? bcoz i found only end connections like Butt weld , Socket weld , Threaded ,Plain end and compression end connections only in PDMS but my client asking me about Mechanical joints something like Bell mounted shapes and some type of end preparations used for sanitary piping etc...........
If it is possible can anyone guide me ........Thanks
IT IS POSSIBLE..you just need to create new coco and add abbr of the joint type in its attrib ctype
eg in your case bell mounted shapes can be abbrevated as BMS
so create new coco with Attrib CTYPE eq BMS BMS ...
so that they can be connected to each other..
Thanks for ur response pitch........Do u have any idea about creation of User defined end connection symbols in PDMS..............I think it's not user definable...right.........?
Suppose if i want bell mounted elbo, I can create the bell mounting shape at the ends of elbo in paragon component creation....but what end connection skey i have to choose for the arrive n leave p-points....If I want Sock-weld i can go for it, but if i want bell mounting shape for elbo in my iso....then what i have to do..?
