General
General
Members Chat Area! To make a piping assembly
  • Replies 9 replies
  • Subscribers 2 subscribers
  • Views 47 views
Vohra Aslam M
Vohra Aslam M over 14 years ago
    Corrado Galluzzi over 14 years ago
    "I made an assembly but can execute in model in design module."
    Could you please explain exactly what is the problem?
  • Vohra Aslam M
    Hi friends.
    I am working on piping assembly. I made an assembly but can execute in model in design module.
    Can any one help me regarding this. Or any important material regarding this.
    Thx in advance
  • john pitchers
    john pitchers over 14 years ago
    The same question in four separate Threads.
    Just a little bit impatient aren't you?
  • Vohra Aslam M
    [QUOTE=pitch;48102]The same question in four separate Threads.
    Sorry dear,
    Actually i am not familier with this kind of updating threat. And how and when 1 can see any reply. So i updated in different forum.
    Once again.....could you please explain exactly what is the problem?
    We need extra info in order to help you?
    Which kind of assembly have you created?
    Which kind of rules do you need?
    etc etc...
  • Vohra Aslam M
    I am getting difficulty in defining rules..i go through the manuals but didnt get properly.
  • Vohra Aslam M
    [QUOTE=corrado;48116]Once again.....could you please explain exactly what is the problem?
    etc etc...
    Actually i have created an assembly..but say if i want to give distance in placing so how can i do it??  I have made one vent and i want to place at a certain distance from elbow on pipe. I m giving value in dist of taping element of parent branch. But it is not placing on that distance, it is placed on elbow end itself. So which kind of value we have to give in defining rule? just prompt me that.
  • R K
    R K over 14 years ago
    Hi ALL,
    I also have the same problem with defining position rule.
    I tried creating a drain assembly with olet on the main branch. I tried to set position on the olet to "DIST 200 from prev" as describe in the manual but it seems the rule is not working. The assembly was created when i picked a component or the tube but the distance rule doesn't work.
    Is there anybody encounter this issue?
    Cheers
  • Nilesh Solanki
    Nilesh Solanki over 8 years ago
    [QUOTE=PDMS_USER001;50289]Hi ALL,
    Cheers
    Hi
    I am also facing same issue. Any update / resolution  ??
