General
General
Members Chat Area! Command Window Justification
  • Replies 5 replies
  • Subscribers 2 subscribers
  • Views 17 views
chris bennett
chris bennett over 12 years ago
  • chris bennett
    Has anyone besides me had the justification of the Command window suddenly switch from Left to Right? The only solution I have seen for this is to exit the program and begin again.  Thanks in advance
  • Abbe Omo
    Abbe Omo over 12 years ago
    Re-starting your workstation is not necessary. All you need to do is 'Un-dock' it from the right(?) and move it to wherever you want it to be located. Hope that is what you are refering to.
  • chris bennett
    I don't think that is what I meant. When typing a command in the command window the text starts from the left side of the window and progresses across to the right. occasionally something changes and the text strings start from the right and slide to the left. Not sure why, just random.
  • chris bennett
    right clicking in the command window allows the selection or deselection of Right to Left reading order. Occasionally this option fouls up and gets hung up in the Right to Left reading order. if there was a text string that could deselect that option, you should be able to fix it from the command line. At this time I don't know what that would be.
  • Dan Maxim
    Dan Maxim over 10 years ago
    You may try the keys combination Left Ctrl+Left Shift.
